Keep in mind, the 'grit' spec will imply completely different performance, depending on which abrasive type (diamond, silicon carbide, aluminum oxide) you choose. A 'fine' diamond grit, like DMT's 600 mesh, will work more aggressively than an identical 'grit' number in a different abrasive type (like aluminum oxide, which is what the Norton India stones are made of). This is just due to the difference in hardness and particle shape, therefore aggressiveness, between different abrasives. Different grit standards for each abrasive type, so directly comparing each type based only on the grit number is risky, and usually misleading.
Having said that, the Coarse/Fine combo from DMT is always a pretty safe and effective choice. I've read here that the Norton stones, in either aluminum oxide (India) or silicon carbide (Crystolon) are also quite good as general-purpose workhorse stones.
