- Mar 19, 2007
I am reviewing these stones for Scandi Knives only. You can use them to touch up and sharpen convex edges, but I use a different sharpening kit for that - so I have much more experience with them and Scandi use.
The first stone I got in was the Fallkniven DC4 - because that is what Ray Mear's sells (and I have never gone wrong with what Ray recommended) and I began to use that.
DC4:
3.94 inches long
1.25 inches wide
Comes with leather case.
It has a diamond side (25 Micron) and a ceramic side. It seems VERY coarse on both sides at first. In fact, I had some fairly deep scratches on my knives at first and I wondered how this was going to work out. The ceramic side appears to be machined (it has large swirl marks) and so when you first start to use it - it is rough.
With that said, this sharpener in the field could take out even dings in blades (although I did not use it for this) and the edge you end up with on your knife (I sharpened 01 and CPM 154) is very sharp and because of the ceramic side, has a lot of bite!
This stone, in my opinion, would last a lifetime but would be used for field sharpening only as the edge that it puts on has scratches is not very refined. This is merely an aesthetics thing - but a much more refined edge can be put on with proper bench stones.
The leather case it comes with is about 6 ounce leather that is fairly stiff. It should last forever.
The only issue I have with them is that they are currently hard to find. I had to pay about 10 dollars over normal price to get it shipped from Sweden.
This cleans up nicely with Barkeepers Friend. I would not recommend using a cleaner with bleach as it can harm the surface of the diamond side.
Doublestuff:
Specs:
Medium Ceramic (303 F) and a Fine Ceramic edge (303 M)
5 inches Long - 1 inch wide - 1/4 inch thick
The doublestuff is a little more expensive than the DC4, a little thinner, but a little longer. It is not as flat as the Fallkniven (the edges are a little raised, but wear in quickly) and a little more tough to use as it not as wide.
Also, the doublestuff is a much more finer grit on both sides than the DC4 and really excels for touching up a knife rather than taking out dings. It could be done, but you would be there a while.
With that said, the doublestuff is super light and very well made. It is PERFECT for an experienced knife user who does not ding his knife often, or takes week long trips or less and plan out working out any dings when you get back.
The edge it puts on is nice (less scratches) and has a lot of bite. I think the Spyderco is a little more refined, but I also think it would loose its flatness over time faster than the DC4 and as mentioned above was a less flat out of the box.
The leather case does that I have with mine does not look like the picture above, it is thinner, more flexible, and looks to be made from swede and not cow hide. However, it is very nice, and I like the fuzzy surface as it makes a grippy spot to put the stone when in use.
This cleans up great with a scouring pad or Barkeepers Friend - and looks new after every use.
In short, either ones of these products are VERY nice and certainly do what you need them to. If I had a harder steeled knife, I would buy the DC4 and if I had a carbon steel knife, I would use the Spyderco - although you could get by with either.
I was very happy with both of these products.
TF
DC4:
3.94 inches long
1.25 inches wide
Doublestuff:
Specs:
TF
