Sharpening Stones
Okay, here's the deal...I have a 220/800 combo waterstone and a 6000 water/finishing stone. There seems to be a definitive gap between the 800 and 6000 and I'm looking to fill that gap.
Question 1: Am I looking at just one stone to fill the gap, or more than one?
Question 2: What grit(s) do I want here? I was thinking maybe a 1200 and a 4000 or maybe just a 3000.
I'm looking to steer clear of anything that requires oil--too messy for me.
Thanks guys...I didn't want to ask yet another sharpening question, but my question was a little too specific for most of the threads that I found in my search.
From what I remember of reading Leonard Lee's book, the 1200 shoudl be fine. a 4000 would be nice to have, but not absolutely necessary. from 800 to 1200 to 6000 will be o.k., but of course not ideal. I hope someoen can confirm this, or clear things up for me in case I am wrong!
The more hones you have inbetween the faster the process will go so buy as much as you can afford.
-Cliff
Damn...I was hoping that wouldn't be the answer...I guess I'm just gonna have to lay down the cash...
800, 1200, 4000, 8000. Works quickly to a polished edge. Most people here apparently think a polished edge is for special purposes only. Many 'hone' to a final edge with a fine India stone which is about 360 on the Japanese grit scale.
re mess: water works fine on 'oil' stones if they haven't been oiled. This gives you more and cheaper options.
http://www.ameritech.net/users/knives/grits.htm
Thanks for the link, dude...I've been looking for something like that.
And if I remember correctly, in his book, Juranitch said that you shouldn't use anything (i.e. water, oil, etc.) when sharpening? You guys every read/try that?
If a stone has been oiled, you should use oil on it. Otherwise, I have always gotten great results not using any bit of oil on my stones. Water stones do need water though.
Some stones need a lubricant as otherwise they will clog up very rapidly, waterstones are probably the worst. Just try one dry and see what happens. You will need to clean it after just a little honing. Some hones like Diamond plates and solid ceramic abrasives can be ran dry as they don't break down in use and thus they don't load up.
-Cliff
