Is this the right one?i have lansky and sharpmaker, Sharpmaker gets used all the time, lansky stays in the closet, save the money and get the sharpmaker , then eventually get the uf rods and the diamond rods. I love my sharpmaker and besides the edge pro or wicked edge, It's the best sharpener i've ever used, and is a whole lot cheaper than an EP or WE
Someone also suggested this:
http://www.amazon.com/Lansky-4-rod-Crock-Sharpener-LCD5D/dp/B000B8FW0E
I saw it was similar to the Sharpmaker.
Vasu,
This kit (Lansky Deluxe) will handle the steels you have mentioned (AUS-8, 8Cr13MoV, 1095 Cro-Van). The 'cheap' knives you mention are a toss-up; I'm sure the steel's hardness or abrasion-resistance won't be a factor with these hones, but it's more a matter of whether those blades will take or hold a decent edge in the first place.
At some future time, IF you feel the need for it, a single supplementary diamond hone in extra-coarse or coarse could also be very useful to speed up re-bevelling on more challenging steels or heavier blades. The small size of the Lansky hones can slow the work down on a very large or thick blade, with lots of metal to be removed.
You are correct in assuming the angle is dependant on blade size. Almost entirely dependant on that, in fact. The positioning of the blade in the clamp will also have some effect; more deeply-set into the clamp will make the angle wider, and further out will make it more acute. If you are concerned about hitting a specific number for your angle, I'd highly recommend measuring it, instead of relying on the marked values on the clamp.
