I re-profiled my Woodlander on the Sharpmaker. Just used the old sharpie trick and diamond stones, went slow with low pressure and a lot of patience, it took me a few hours to get a uniform angle on the entire edge . Mine did have a convex edge but I've found a V bevel has worked fine for wood processing.
They were flat ground with thick convex edges from the factory. Both of yours have thinner convex edges (still pretty robust) that cut better. Ideally you should maintain the convex and even better grind it even higher. If you don't have a belt grinder sand paper and time will work..
Both the ones you have should have sub 40 degree included edges and edge upkeep with a Sharpmaker/edge pro should be fine. Unless you plan a full regrind.. a 1X30" belt grinder is good, 2X72" is a lot better.
30 included on the Domino please and no need to wait for a Techno to arrive (that trade fell through)
