Hi All,
Since I started using EdgePro a few years back I have come to realize just how many blades have edges that are not ground at the same angle from handle to tip. Usually the angle steepens over the last inch or so as the edge sweeps up to the tip, often by two or three degrees.
By ignoring this and sharpening the entire edge at the same angle as the straight part closer to the handle inevitably leads to a widening (and often unsightly) bevel towards the tip.
If I understand the terminology correctly this is a feature of blades that lack full distal taper and the edge is moving across thicker steel as it sweeps to the tip.
I'm curious as to how other EdgePro users deal with this issue: suffer the widening bevel, sharpen the tip seperately at the slightly higher angle which tends to leave a noticeable border where the two angles meet or has anyone devised a clever method for retaining that gradual transition between straight angle and tip?
