I found that one side of the blade was fine while the bevel on the other side was rounded off for part of its length, resulting in a edge that was only partly sharp. This meant that I really needed to re-profile the bevel to get a good edge.
I would recommend not starting off using the diamond rods! Especially if the edge is already sharp. You will just remove metal unnecessarily from an otherwise good edge. The diamond rods should only be used if the edge is non existant (such as a spoon). You can easily ruin an edge by using the diamond rods to excess. Sticking with the coarse (grey) stones and the ultra fine (white) stones for daily touch-ups will eliminate the need for the diamond rods.
I've been able to get my Sebenzas screamin sharp on the edge pro apex. I set it on 21 degrees (when you lay the knife on the table, the hollow grind needs two points of contact in order to keep the knife stable while sharpening. This brings the angle down 3 degrees to about 18 degrees.) I rough in the angle with the course stone then I go to medium then fine and I finish with the extra fine (600 grit).
