Sharpening the Team Gemini
Hello fellow Busse lovers,
what is the best way to sharpen my Busse Team Gemini? I think it has full convex zero grind.
edit: I found how to sharpen convex edges, easy with a mouse pad. But in this case I am not sure, since it is a zero grind.
Thanks in advance,
itadakimasu
I have sharpened mine on a dmt duo fold red/blue sharpener, a ezlap diamond sharpener and a mouse pad with wet dry sandpaper and a leather strop. They all work to put a good razor edge on.
What Dave said!!!:thumbup:
Thanks for the input guys. Do you put the whole side of the blade on the sharpening medium, or just a bit? Like creating a micro bevel?
micro bevel, that is how I do mine. I like my stones. :)
Its also good for coated blades if you want to keep it intact for the most part. Some of it has to go regardless.
Exactly what Leatherman said, I just put the last bit of the edge on the paper and try not to take the coating off higher up. generally it comes out looking like this.
or this
Exactly! :) Mine end up looking more like the bottom picture. I always end up removing some of the coating because of the blunt nature of the coated knives, its not a big deal and improves the cutting so much. My Heavy Duty lost quite a bit of coating when I raised the profile to make it slice better.
By the way, FYI, the coating will load a stone very quickly but will scrub out with a green scrub pad and some Comet cleanser or other powdered cleanser. This works especially well on ceramic stones, the metal and coating rub off after a little elbow grease.
Hey, thanks for even putting more information out. The thing is that I have a Team Gemini from the recent Ganza with the satin finish. So my thought now was to use a mouse pad with sand paper and just put a micro bevel on it. I don't want to ruin the beautiful finish with unnatural scratches. Scratches from using it, are not a problem, but I don't like the idea of sratching it while sharpening it.
Anyway, I am not sure how I could sharpen it the way it is sharpened right now, without destroying the finish. Therefore a micro bevel seems to be the only way with the tools I have here. This is my first knife with a convex zero grind.
Edit: I am sorry about my ignorance about the knife. As it turns out it has a flat primary grind and convex edge bevel.
The best thing I have used on convex edges is the Worksharp. Just be careful around the tip. I use mine without the guide.
Even with a convex zero-grind, sharpening is the same, altering the edge-geometry via grinding at a steeper angle to produce a more robust edge. With a full convex grind that is apexed (sharpened) with a convex grind, the edge-bevel simply blends better into the primary.
