That actually doesn't look too bad; I'm assuming that's the Sebenza? It looks like most or all could be done by grinding down the spine near the tip. I've used a small pocket diamond hone in this way, on some of my knives. On that Sebenza's blade, it's convenient that the forward end of the blade's spine is essentially dead-straight, from the very slight 'drop' at about 1" to 1-1/4" from the tip, all the way to the tip itself (I'm comparing to the small Seb I have). Easier to lay a hone flush to the spine in that forward section, and 'file' toward the tip. Go in that one direction only, so as to avoid blunting the tip if the angle varies while moving in the other direction. A diamond hone in Fine or EF is probably what I'd use, ideally (assuming S30V). The spines on Sebenzas are somewhat radiused (not flat/square), which means some filing with a diamond hone will flatten that a bit. So, the cosmetic damage in filing it down would be somewhat minimized using a finer hone, though it'll take a little longer.
David
