sharpening tips for the f1
juist wanted some advice on the best way to maintain and than resharpen the edge on the f1...the factory edge is awesome and real sharp for such a thick blade the packaging says to use a a diamond or a whetstone and pretend like you were taking slices off of it. Howeve I know many people prefer to sharpen a convex gring using the old mouspad and sandpaper method. I'll just strop on a belt to maintain but I imagine that'll only last for so long...and I suck at sharpening...so the more idiot proof the better. thanks.
I use a ceramic whetstone. I push the blade from the edge to the spine follwing the convex grind. I've heard good things about the use of a mouse pad but have never tried it myself. Hope it helps.
dantzk.
Go to the Bark RIver website and find the tutorial on sharpening convex blades. They use sandpaper on a mousepad, which is idiot-proof (I should know).
For Convex maintenence I use a strop with that green cutting compound on top. If you stay on top of the maintenence I've never had to really remove a lot of metal, although I've heard the sandpaper/mousepad trick works well.
You can make a great strop cheaply. Or you can do the mousepad and sandpaper trick. Or you can do as HD does, I think his system is awesome!
For a cheap strop (or you can do a mousepad on a handle this way):
-Next time you're at Home depot get a couple of paint stirrers.
-Glue them together using carpenters glue.
-Cut a couple of pieces of leather to fit the width of the stirrers. An old leather belt works great for this (see Goodwill).
-Contact cement the leather strips to each side of the stirrer glueup.
-Load one side with emery compound. (fast cutter)
-Load the other with a polishing compound.
Man, you just saved a buncha dough and got one every bit as good as a Lee Valley.
-To use a mousepad, just cut it and contact cement it to the stirrer.
-Get some 3M spray adhesive from Home depot.
-Spray the mousepad, and the back of the sandpaper
-Wait 3 minutes
-Stick them together.
-3M spray adhesive makes a temporary bond so when you wear out the sandpaper, peel it off and do another round of spraying.
TIP --- When learning to sharpen a convex edge use a permanent marker to color the edge. ****Use light pressure and check the edge every few strokes.*** If you're not getting all the way to the edge, change the angle, not the pressure!!!!
Edit: Oh yea. Use 220 grit paper for bad edges, and 400 for fine ajustments.
