Well I have a srk cold steel san mai a buck 110 and a centafante3... I'm using dmt coarse fine extra fine and a spyderco ultra fine to finish... for some reason it seams once I get to that stone I am making a microbevel with a mirror finish instead of the whole edge and I have no idea why... like I said I use quarters to keep my angle consistentnt for now as a begginner so I don't know how that is happening
Hi,
The good news is only the very apex of the edge needs to be polished, nothing wrong with microbevels
See what is happening is you're increasing the angle
or holding it more steadily, with the spyderco ultra fine stone
Did you tape the quarters together so they don't shift?
Are you putting the quarters on the same part of the spine each and every time?
How many hands are you using to hold the knife while your sharpen?
See when you're sharpening freehand there is always some wobble creating curvature,
esp with one hand versus two hands,
esp if you dont have any fingers on the blade
when I started two years ago, I was using one hand,
and I had lots of wobbling even with a wedge for angle reference
i had a tendency to lean towards the shoulder of the bevel (back towards spine)
knife would get sharp but it will be very noticeably convex
If you paint the edge bevel with a marker and take a stroke or two you can which part of the bevel you're hitting
if you want a flatter edge , and you're not wobbling intentionally by wobbling your wrist,
change your grip,
when going away from yourself, keep thumb on spine (of blade or handle),
when going toward yourself , keep thumb on the side (of blade or handle) like a pinch grip
you can also use index finger on spine but usually not required
if you're not holding the stone in the other hand, you can use your other hand to
to put a finger or two close to the edge to increase control
and if its a wide enough blade you can even hook a finger on the spine
it also helps to keep more of the edge on the stone by the blade diagonally across the stone
naturally going slower also helps for control, but that can get annoying
you can always lean your stones horizontally or vertically sharpmaker style
