- May 18, 1999
Well I have had an experience that reenforces my belief in softer knifes that can be sharpened with regular stones as well as my belief in the DMT Duofolds and other diamond hones.
Personally I like the harder blades as they last a lot longer in between sharpenings but you need a diamond to sharpen them if you're going to use a hone instead of the mousepad and paper.
Munk sent me a little Browning stainless steel knife that he had worked on along with his 25"AK for me to rework. Munk was pretty close but, and I'm sure that eventually with a lot of time and effort that it could've been sharpened with a regular stone but to say it would be difficult is an understatement.
It took me about three or four hours with my EZElap and then finally the DMT Extra Coarse Duofold to get this little knife sharp as a knife should be.
So I'm going to say it again, "If you're having trouble sharpening your hard sweet spots and can use a hone then get yourself some of the DMT Duofolds."
They came in an Extra Coarse & Coarse, Coarse and Fine, and Fine & Extra Fine.
You only need the first two as the Extra Fine is overkill AFAIC.
Using the Fine grade as the finish hone and then stropping the hell outta the knife will make for an excellent edge.
