It seems like I'm getting 3 out of 4 blades to sharpen these days that are beyond dull. Blades that have either been used really hard and sharpened poorly or blades that have been used for literally years without a single sharpening. In most of these Used and Abused blades, I find some amount of recurve in the middle or rear portion of the blade.
Some are so pronounced that you can easily see it just looking at the blade. In others it shows up as just a thinner bevel in the recurved area.
So far my approach has simply been to sharpen as I always do. As the burr begins to form, I focus on the areas where the burr hasn't formed yet and it gradually creeps down or up the blade (or both). As it approaches the recurved section, I usually hit a point where I have to grind and grind and grind and grind some more with no burr forming for a long time. I realize that what I'm really doing is grinding down the surrounding area of the blade, so that the recurve can finally touch the stone properly and grind the bevel in that area.
In fact in the surrounding area, especially at the heel, the bevel gets wider. So I end up with a bevel that is normal to thin in the area that was very recurved and a wider than normal bevel at the heel and perhaps in the immediate area closer to the tip from the recurve. The overall blade shape flattens out as well, but it doesn't become perfectly flat; part of the recurve generally remains.
I've tried focusing on the recurve area by using pressure from my support hand right over that area. It helps for sure. I've tried grinding with the heel or the tip of the blade *not* touching the stone so that I'm almost sharpening the recurve on the edge of the stone. With diamond stones I don't like this because the point pressure can strip off the diamonds. It also feels like I'm cheating the blade and not reforming the edge like I should.
I've considered biting the bullet and grinding the edge down flat, edge first, into the stone until the recurve is gone. But that's going to leave me with a very, very blunt edge and I'm not even sure that I'd get the bevel even starting from that point.
Wow that was a long explanation.
Anyone have any wisdom to share? Maybe I just need power tools. That Ken Onion edition Work Sharp is on my radar.
Thanks,
Brian.
Thanks,
Brian.
