Anyone ever try this? I was digging through some old stuff, and came across an old paint scraper with a removable scraper bit, about 2" long, 5/16" wide, and about 1/16" thick, trapezoid shaped in cross section. Have no idea what it's actually made of. Whatever it is, it's really hard. So far, I've taken it to a Buck 119, a SAK, a Mora, and a Tramontina machete. The results have been pretty good, particularly after I lapped it a bit on a flat piece of ceramic to clean up the corners. It basically scrapes away steel. A fairly crude method, but if the corners are sharp, it takes little effort, and one doesn't remove much material. I did have difficulty on a cheap stainless "Rambo" knife, which wanted to burr even with the lightest touch. The others went pretty well. The Mora, with the hardest steel of the bunch, responded better than I expected.
I've tried those cheap V carbide sharpeners before, but using this freehand is a much better solution. This sort of thing might be a good, minimalist field sharpener. I think I may epoxy the carbide in a small wood handle for easier use.
