If your dad's belt sander is something in the range of 1" by 42" I wouldn't recommend it(unless you can adjust the speed to a low setting). The belt will either eat your blade or damage the temper.WOW thanks, this has really given me an idea of what I will use. My dad has a belt sander at his work I can look into using, or I will check out the variety of stones
Second, you raise a burr along the entire edge, both side. The burr forms when you've sharpened one side of the edge as much as it can take.
Third, you gently remove the burr so you get a refined and durable edge.
I'm still trying to answer that question, a lot of the guided stuff plain doesn't work (Accusharp.) Powertools can be dangerous and also expensive, and it can be really easy to ruin a knife. Freehand and rods/steels can also ruin your knife if you don't hold your blade at a constant angle. Guided is the best option, I think. Since you have made an account on Bladeforums, you can ask everyone here as many questions as you want, so finding a quality sharpener shouldn't be difficult. If you do buy one of the more expensive guided tools, it will last you pretty much forever.
The last point I will make is this; what ever you do, don't start off sharpening your older knives. Buy a crappy knife that you can practice with. You can always buy another Benchmade, but there are only so many WWII knives out there. I've made this mistake, and I need to re profile my USMC Ka-Bar.
That's just plain not true. The learning curve for using the belt sander is not very steep. I started with an inexpensivve Harbor Freight 1x30, which is pretty high speed and didn't burn even one blade. Sure, if you just go at it willy nilly and don't think about the heat your building in the blade you are going to screw up. Belt sander is the fastest way to a polished, refined edge.
