- Aug 24, 2012
With the recent thread on stone sharpening vs grinder/belt sharpening. Like to see how you all sharpen.
You should add a both or other voting option.With the recent thread on stone sharpening vs grinder/belt sharpening. Like to see how you all sharpen.
I am making kitchen knives right now so all my grinds are zero or very near zero ground so there is no need to use a grinder to sharpen them. Only takes a minute to sharpen them on stones.
Hoss
I use the solid DMT stones. I also like norton combo oil stone. I have some water stones also. Technique seems to be more important than equipment. The different stones have different strengths. FWIW, I use windex with the norton stone.
Hoss
Vitrified CBN Waterstones.
The belts don't cut high Vanadium steels at high Hardness like 10v at 64rc very well.
Where can I get some of those CBN water stones?
Hoss
There is academic information one can read that doesn't apply to stones.I've never used CBN before, I've read as much as I can on it though. What advantages would you say that it offers over diamond abrasives in low speed applications?
The Vitrified bonding is the the most important thing, I felt it was more compatible with the bond I like. I also selected the CBN over diamond cause I liked the finishing characteristics. It should be noted that CBN is more expensive than Diamond. CBN is not as hard as diamond but I find the structure of the abrasive grains more suited to the cutting speed and finish I'm looking for with this stone.
