Sharpening
So I had a Lansky for a while and it wore out. Stepped up to a KME, but I find I get micro abrasions on the back part of the blade, behind the edge. I know I could tape everything off, but that’s a pain and I never experienced this with the Lansky. Thoughts on why the KME is doing this?
Also these sharpeners suggest a degree of edge, but that depends on the width or size of the blade. So it’s not really accurate, right? Am I thinking about this correctly?
Suggestions on a set of flat stones???
Tried a spyderco sharp maker. It’s good for touching up I guess.
What should I get without spending $800 or so on a Wicked Edge?
I just want something that works pretty well and doesn’t mess up my blades. Thoughts?
I've been freehand sharpening for close to 40 years now and DMT has the best sharpening stones in my experience. I used to use old Arkansas stones that you can get at any maw and paw tool shop around here. I discovered DMT and have been using them ever since. I have a set of DMT stones that are close to 25 years old and I still use them to this day.
I use DMT duosharp stones (320 - 600 - 1200 grit) and in the "field" the little double sided diasharp stones which I love. Years of free hand sharpening and I'm just about there now😉
I prefer free hand as its easy/convenient to do when out etc... especially with the smaller stones. On my Japanese and better higher carbon knives I'll also use water stones.
I'll add another vote for the DMT plates...built up a collection over the past year or so, 6", 8", up to the large 12" with the plastic holder and magnetic adapter (which both can also be used with the smaller plates in different configurations). 220 to 8000 mesh (60 to 3 microns). Plus a collection of their folding sharpeners in round and flat. Getting really good results by now.
Wicked Edge has the new WE60 Go for sale now. It's a lot less than $800 and is a nice setup for new guys. I also bought the aluminum base that is available now for the WE60 and it is nice. It is also heavier than I thought it would be and has some nice rubber feet on it.
But the web site recommends the WE130 for fully flat-ground blades. Can you do FFG blades with the WE60 GO? I've never had any trouble with them on the Work Sharp Precision Adjust, which has rubber pads on the clamp.
Yes. The WE60 has the newly designed jaws that make clamping FFG and distally tapered blades much easier. I love it. I hope they offer the new jaws made for the WE130. When they do I'll be ordering myself a set of them.
With the KME:
You will need an angle cube if you want to be precise. I use an iPhone, which is (usually) close enough for me.
If I’m reading you correctly, by micro abrasions do you mean small scratches behind the edge? I’ve had that problem also. I haven’t noticed it since I started wiping the sharpening slurry frequently. I’m interested to hear what others have to say about it.
First use of KME, putting a 30 degree edge on a Benchmade 710-D2, found scratches above secondary bevel as you did, during inspection after one of the flips changing sides, with NEW KME 140 grit diamond. It was clean and used, so I was bummed but got over it after using the 710 a while. My enthusiam for using a new tool overwelmed rational thinking which would have had me sharpen some thrift store finds before a benchmade... Never scratched anything after that with KME. I considered it driver error. The KME diamonds are great stones and long wearing but need breaking in.
Taping is a common strategy for protecting blades, I always have some blue tape around.
At the moment I am reprofiling a 710-1401 for a friend. I'm at KME's 600 grit stage, without thumbstudes. Both 710's are very symmetrical at the secondary bevel so they do not have the wider edge nearing the tip, nicely ground primary bevel's from the factory.
I'm expecting well over 400 to 500 sharpenings with each KME plate, using a light hand hand and wet water.
At one point in the past I assumed 6 inch plates would be obviously better, but for several housholds these 4 inch KME plates work great for the home / kitchen / field / garage users, and are more economical then 6 inchers to replace when the time comes. I have spent time looking for 6 to 8 inch thin plates built as robust as KME, and the best I can come up with are DMT solid more expensive plates, duh.
The exception in stone length is vertical V-sharpeners like the Sharpmaker or Idahone's 7 inch trangle standard, and Congress Moldmaker's at 6 inches. For my hands the KME 4 inch plates are too short for vertical use. Maybe smaller younger hands would not have a problem with 4 inch stones. Just set up two 1/2 triangle Sharpmaker kits using Idahone's coarse ceramic which is finished to 100 to 200 grit, their medium at 500 grit, a sharpmaker medium 600-800 grit, an Idahone fine 1200 to 1500 grit, and sharpmaker's fine finished to about 2k grit. Compared to Idahone's coarse ceramic, Congress's Moldmaker 240 grit did not seem to cut differently enough, in my experience, to gift to one of the houses. Going to mount 6 inch by 1 inch EdgePro form factor diamond stones for one house's kit that has super steels.
Gritomatic is showing about five LeadinEdge V-Sharpeners fully assembled at the bottom of landing page (and a room full of 3D printers), taken from their Instagram feed. So I keep waiting for them to finish building inventory and start selling. Hoping Sharpmakers flats and edges will work with stone holder. Asked if I could buy n test early unit, but did not get any play, o well.
