Hi everybody!
What do you think about sharing our sharpening techniques, systems and oppinions?
My sharpening technique uses a medium-fine grit stone, fine grit sand paper, a piece of leader, a broomstick and three clamps.
I start with the stone alternating each side of the edge. Each strike i done allways in the opposite direction one uses to cut. The edge is allways perpendicular to the line of stell dust that forms on the stone surface. Each strike starts on the tip and ends on the bottom of the blade in order to cover the whole edge on each strike. When the edge grabs your upper finger's skin put the sand paper (800-1200 grit) arround the broomstick and polish until it's almost a mirror ten repeat using a leader piece.
Your edge should be good shaver at this point tough it won't be as sharp as my scalion (kershaw).
Try it and good luck
