I have good luck with the Diamond rods for the Sharpmaker. You will have to invest time and effort with any hand sharpening system to reprofile the latest and greatest super steels. The Diamond rods for the Sharpmaker do save you time when you consider what you would have to invest to do the same sharpening with just the brown rods that come with the Sharpmaker. Are there more coarse sharpeners out there? Yes. Do they fit in the Sharpmaker that you already own and know how to use? Probably not. Can they be adapted to work? Probably.
In the end the choice is if you want to be able to use the Sharpmaker base for the entire sharpening session or if you are comfortable switching between some other method (free hand, adjustable angle tool, power tool, etc) and the Sharpmaker.
For me it depends what and where I am going to be sharpening. If I'm at home and I have a lot of metal to remove, I go to a belt grinder (Grizzly 2"x72") to bring the two bevels together, then use a power strop (richard j buffing wheel). If I want a finer polished edge at home I start with the belt grinder and then I switch to the Sharpmaker. If I am away from home, but still have access to 110v power, I use a small portable belt sander (Grizzly or Harbor Freight 1"x30") then the Sharpmaker. If I am headed out into the woods or where I am not certain power tools are appropriate, I just use the Diamond rods and the regular Sharpmaker setup. It takes more time, but still gets me to the type of edge that I want to have on a knife.
