- Oct 8, 2013
Does anyone just use the flats to sharpen plain edge blades exclusively?Or are the corners required to set edge after a reprofiling.
I almost exclusively use the flats but I do find the corners work a little better on a recurve blade. At least for me.
Andrew,Another good use for the corners is the heel area next to the tang. That part is often incompletely ground from the factory and needs some work. I set my initial bevels with a Work Sharp KO but often can't completely sharpen that area without adding an unwanted "recurve". So I'll stop short and go to my SM. The corners allow you to focus in on just that very small area and bring it to apex.
What I was wondering if the corners do a better job of cleaning up the edge that is burred after a reprofiling than the flats seeing it is more aggressive?
... Another good use for the corners is the heel area next to the tang (Italics mine). That part is often incompletely ground from the factory and needs some work. I set my initial bevels with a Work Sharp KO but often can't completely sharpen that area without adding an unwanted "recurve". So I'll stop short and go to my SM. The corners allow you to focus in on just that very small area and bring it to apex.
Andrew
