- Mar 19, 2018
Hello I recently got my gurka kukri in 01 steel and it’s great for chopping. When the edge needs touching up all i have is a sharp maker is this ok to use? Thanks
Thanks mate im glad I read this before getting the sharpmaker out as I would have just used the same technique as my normal fixed blades. Cheers.The Kukuri is kind of a hard shape to sharpen because it has a recurve at the heel and a bulbous outward curve at the front. If you've watched SharpMaker videos or illustrations, you'll be familiar with the operator rotating the handle of the blade *down* as he goes through outward curves. Inward (recurve) curves require the opposite: As you go through the recurve you should move the handle *up*. To do this correctly you need to start the recurve portion with the handle nearly all the way down, then rotate up as you go through that portion.
Then, as you do the outward curve, you reverse your rotation and go back down. It's kind of a weird "S" motion and that's kind of a long blade. You can get it done, but if the blade requires more than touchups, you will probably want to use something else.
If you do this motion wrong, you will probably ride up onto the shoulder of the blade, or come WAY down on the edge creating a small micro bevel. So, if you do this wrong for a good number of passes, you will be creating a new bevel in "the wrong place" wandering around on the blade. I don't say this to discourage you. Rather, I noticed that this is quite an expensive blade, so I thought I'd caution you about what might happen. You might consider practicing on something else kukuri shaped (that's cheap) or seeking another method that you can control more precisely.
Good luck.
Brian.
C ckdexterhaven Functionally how is that different from an Idahone?
Hi,I didn't know about the Idahone but from what I can see the Idahone is ceramic similar to the Sharpmaker stones. I think the ruby is probably much faster similar to diamond.
Hi,Thanks mate im glad I read this before getting the sharpmaker out as I would have just used the same technique as my normal fixed blades. Cheers.
