In regards to SOG, I used it as a low end for sharpness as that has been my experience with the NIB SOG blades I have used as well it has been clearly stated by SOG that the knives are *not* designed to push cut paper but only to slice paper at an angle - this is on the very low end for sharpness, far below the NIB standard for Spyderco. They have also pushed the knife myths of very sharp edges being weak and so on.
DB :
Did you notice if sharpening pressure made a difference?
In terms of scratch pattern, no. The abrasive depth here is about one micron and thus the difference in force from what is required to make a scratch to that which is necessary to drive the abrasive full depth is *very* small and thus you make the maxium depth scratch.
Jeff Clark :
If you read Cliff's review SOG's navy seal style knife I don't see him "having it in for them".
Yes, but you have to actually read the review to come to that conclusion.
[poly slicing]
In a previous test you ran using a rougher edge finish on thin blades I thought you got the opposite results.
I have done this before with more grits, ref :
http://www.physics.mun.ca/~sstamp/knives/vision.html#grits
As the abrasive gets too coarse it requires more force to slice on the draw, when finer it starts to be able to put cut through the poly and thus the slice becomes less of a draw. Note though that this is very material specific, 1/4" poly is very soft, a hard shelled "plastic" rope would give different results in favor of the more abrasive grits.
In the Vision chart the results fall off *fast* with CrO. Based on experience sinve that time, I now see that as having been significantly influenced by techinque, specifically edge rounding. If I get some time this week I may redo some blades with the fine Spyderco rods and then give them some work on CrO, say 5, 10 and 15 passes (or something similar) and then record the performance on the thread, poly and rope.
The interesting thing will be that while the polish will be raised on the edge due to the finer CrO, the sharpness will be degraded because the edge anignment and consistency will be down significantly because you are comparing freehand to basically a jig, and edge-into vs edge-training which is directly inferior.
I will also keep a lookout for some hard shelled rope.
[rods]
I figure that the edge is subjected to a lot of local overstress when you use the hone edges. I would expect the edge to be less durable.
Rods are among the worst sharpening implements in that respect because if you use too much force you can actually ripple the edge (like the much hyped brass rod test). Even if you don't visually see it bend, as you have note you can cause local defomations which lead to fracture with extended use. You have to be careful to exert just enough force to get the abrasive to just cut. With these blades this wasn't a problem because they are simple steels and thus easily machined and thus will hone under very light force so there is no danger of rippling. With steels like D2 I don't like rods and perfer flat stones as you tend to have to press really hard to get them to sharpen. Rods work best here if they are diamond abrasives as they cut under the least force.
I think you should try some performance tests using the flats of the rods.
I used the corners simply because I was comparing the edge to that produced by the DMT rod so wanted a direct comparison, not a flat ceramic vs a round diamond. It would be interesting to see though if you could get the edge sharper with the flats and if the scratch pattern was visually influenced, again this is dependent on the steel type and hardness as well.
I would scrub the rods with sink cleanser before the test to get the most open grit condition.
Yes, this was done.
thombrogan :
I wish I could get that tree-topping effect with my Sharpmaker ...
These blades have a primary edge angle which is very acute and thus the honing immediately set a micro-bevel that was a small fraction of a mm wide. This meant that you went from being very blunt (<10% of optimal sharpness), to full sharpness in just a few passes, thus sharpening is *very* fast. In addition they are easy to machine simple steels. Doing this without a micro-bevel on something like D2 would be *MANY* times more difficult.
Sal, no problem
-Cliff
