On CRK's website it states the following:
Now I have a couple questions about this.
First, what does rolling your hand mean? I'm thinking it means as you draw down and across the stone when it gets to the belly right at the tip raise your elbow or drop you hand so the tip drops. Is this correct
Second, What do they mean by the blade should turn away from the crock stick?
SHARPEN WITH A ROLL
Beginning at the widest part of the blade and moving toward the tip, make a downward motion, while rolling your hand. The blade should turn away from the crock stick, as you move around the belly toward the tip. It is important not to sharpen with a purely vertical motion as it will eventually decrease the length of the blade, leaving the knife with a thickened tip and unbalanced geometry. Move back and forth between each crock stick, maintaining light, even pressure.
