- Sep 6, 2011
Which one is the best option for sharpening? Is it easier for a novice to use the sharpmaker or stones?
Good 'ol waterstones.
I've tried it all and the only things that gives a true razors edge is the human touch with some stones.
I don't think there's a learning curve at all. Most people sike themselves out with stones thinking that there's some ancient secret to doing it by hand but in fact it reflects directly what you intend on acheiving in terms of sharpness to toughness. It's really beats all the others "systems"'out there IMO and the sharpKiller really is a waste of cash. Don't concern yOurself with over precise degrees and angles, just produce what you want.
I must respectfully disagree with you, sir. I used stones for several years and was never able to achieve a satisfactory edge.
Currently, all of my knives ae sharpened on an Edge-Pro "Professional" or a WEPS. They are all either as sharp, or nearly so, as my razors that I shave with.
Even highly abrasion resistant steels like S90Vand M390 can be easily brought to this level in a rather short time with these devices.
Obviously, both of these sharpeners have a learning curve. You don't get razor edges "out of the box." However, the learning curve is short, compared to free hand sharpening.
I should also point out that either of these devices, with accessories, will cost far less than a decent set of Shapton or Naniwa waterstones.
The biggest problem with learning free-hand is failing to understand what you're trying to accomplish and identifying where your technique needs work. A little understanding and you'll have a skill that will serve you till your eyes and hands fail you.
If your free hand edges are satisfactory to you, then you obviously have the skill set needed to sharpen to your satisfaction. I suppose my only comment would then be, "more power to you!" :thumbup:
