- Apr 23, 2003
I thought I was going nuts...
I bought a used BM705 on eBay for cheap to use as a beater. I liked it so much, I polished the scratches out of the blade and decided to re-profile the edge to a 30deg included angle.
The problem was when I switched to the fine stones. I worked off and on for a day and a half and noticed on the top of the bevel was getting touched. Down toward the edge was still "rough". First, I made sure that I was keeping the blade vertical. That wasn't the problem.
Long story short...
I taped a piece of paper to a wall and set the Sharpmaker up first with the brown rod and used a very sharp carpenters pencil to follow the flat of the rod on the paper. Then I did the same with the fine rod. Aha, the angle was a bit more acute with the fine rod. So, out comes the calipers and sure enough, the brown rod is about 0.007" more narrow from corner to flat than the fine stone.
I didn't take a bunch of measurements of the slots in the base to work it all out as the proof was right there on the wall, so to speak.
Up until now, I've only used it to touch up edges and hadn't seen this.
The question is, now what the heck do I do?
Thanks for any help,
Tony
Long story short...
Tony
