I'll stick with my original advice. These shouldn't chip that easily under normal use. If you're able and willing to sand it to fix it, that's fine. But I'd still call it defective. I'd be willing to bet Spyderco would replace it, if it's chipping that easily. I've been using a Spyderco Double Stuff hone for 10+ years now (made with the same brown/white ceramic), and I've never seen any chipping issues with it. I could see, if they are frequently rattled/bumped against one another, or dropped on a hard surface, that could crack them and lead to chipping issues. They do need to be handled with some care.
The ceramic hones are made with aluminum oxide, if I'm not mistaken. I think most wet/dry sandpaper is also aluminum oxide. Relatively same hardness between the two, so I'm not surprised that the sanding hasn't had much effect on the fine hones. I think most who've been able to sand/lap ceramics successfully, have done so using diamond abrasives.
