- Jan 15, 2017
I have a couple questions about using a sharpmaker.
First, usually I can get a blade sharp with it. I was sharpening a friend's Kershaw in 8cr13mov the other day. I have the medium brown rods, fine white, and very fine white. I don't have diamond or CBN. I could get the one side sharp enough to catch my thumbnail but it skated going the other way. Like I got one side sharp but not the other. I started over about a half dozen times and while it improved, I expected to be able to do more. FWIW it was very dull when he left it with me. I've sharpened 1095, 440c, and even touched up m390 with the same set up and get much better results. I've sharpened other Kershaws and a Byrd in 8cr13mov in the past and ended with a edge that shaved hair from my arm. Any idea what the problem was?
Next, how much difference does only using the corner of the rod vs the corner and flat?
Finally, I follow the instructions that came with the sharpmaker but I've seen others suggest skipping some steps. Can you give me a brief description of the procedure you follow for using an SM.
Thanks.
Thanks.
