BJE
Basic Member
- Apr 12, 2006
I have read a few time here on BF using a course benchstone on their SM, does that keep the same angle or does it change from the 15 or 20? I would think that if you added the thick benchstone, it would change the angle and make it steeper (10 degrees or less), but I was never very good with Geometry, would the angle not change as long as you had the stone flat against the rod? Could someone please set me straight on this. Also, how effective is this trick? Also again, if you had two different benchstones of different thickness's, would that mess up your angle? Thanks for reading and hopefully helping.
