Hi guys!
I've been trying to reprofile several of my knives on a sharpmaker. I have used rubber bands to attach a DMT extra coarse stone onto one of the rods. The set up is quite stable, but there is a problem that I am encountering. The left side edge would be 40 degrees, the other a little over. I would determine that through the sharpie trick. So I'd run the right side edge on the DMT stone until the sharpie was gone. To confirm that the knife was successfully reprofiled, I'd use the sharpie again, and discover that this time, the right side edge would be 40 degrees, while the left side a little over. So I'd run the left side through the stone and well, the left side would be 40 degrees and the right side a little over. On and on this cycle would continue. What should I do?? The knife that I'm currently attempting to reprofile is a CRKT minimalist, and from the sharpie trick I have determined that both edges are about the same angle now, so any solutions to keep the said issue from happening and successfully reprofilng my knife would be amazing!!
