- Feb 6, 2000
I've had my SharpMaker (204) for close to two years now. I've really improved my skill in its use. Believe me, I'm no expert, but here is what I have found to work for me:
First off, I don't use the flat sides of the stones. I don't know if it's just me, but I had a hard time getting the edges of the blades to be consistently flush with the flat sides of the stones on both sides of the V. I had no problem with using the corners, as I only had to worry about getting one angle right (making sure the face of the blade is vertical). The only purpose I can see that the flat sides of the stones fulfill that the corners don't is spreading out the load of the sharpening. The way I figure it, this aligns the very edge of the edge better because you're not rolling it or misaligning it (on, perhaps, a microscopic level). The corners don't spread the load, and so the final edge is not as sharp as with the flats. I solved this problem by quite simply doing the last 10-20 strokes progressively softer. The last few strokes are feathery soft.
Secondly, although I've been sharpening with this system for a long time, I concentrate on getting the blade vertical every stroke on the stones I take. I don't watch TV or think about other things; to get good results, I have to concentrate on what I'm doing.
Thirdly, even on touch-ups, I use the grey (medium) stones quite a bit. The fine stones hardly take off any metal.
Lastly, I do a LOT of strokes, probably 100 total for the average sharpening job.
(Also, I don't try to reprofile with the SharpMaker. I use a belt sander or very low grit sandpaper for that (I've started using Cliff's loose-belt idea recently). I've also used diamond stones.)
I manage to achieve hair-popping sharp edges using these methods, quite consistently.
If you've been having trouble achieving great results with the SharpMaker, you might want to give these tips a try. They work for me!
