Sharpmaker VS Lansky
I have seen a lot of recommendations for the Sharpmaker.
How does the Lansky shape up - only reason I ask is that I bought quite a fancy setup - and it seems to work perfectly - did I buy a lemon ?
To me the biggest difference between the two systems is the time it takes to get an edge. With the Sharpmaker I just leave it setup on my desk, and whenever needed give my knife a few quick swipes and it is sharp.
With the Lansky I need to mess with clamps, screws, and different stones. Takes a bit longer, and it is more likely to scratch a blade with the clamp unless protected with tape, which would take even more time. I do prefer the LAnsky for when I need to remove a lot of metal, as I don't have the diamond stones for the Sharpmaker.
Bottom line is if it works for you, and you are satisfied it is good.
Love my Sharpmaker, but I don't like trying to reprofile with it. I don't know whether I should (1) get the diamond rods; (2) get a Lansky; or (3) yikes -- get an EdgePro (but it's so expensive).
I have all 3 the lansky, sharpmaker and an edgepro apex. I use the sharpmaker only for maintaining an edge, if I dull the crap out of it I take the time to setup the lansky. I give up on the edgepro, too long of a learning curve for me to produce a nice edge. It will however remove material pretty fast.
I just recently picked up the Sharpmaker, I used the Lansky for many years before that with no regrets.
I have a number knife sharpeners, including several clones of the Lansky and the Sharpmaker.
They all have their good points and uses.
I find the Lansky type of sharpeners won't do recurved edges; and, in fact, they tend to damage them.
The Lansky I have is probably 20 years old- that was pretty much state-of-the-art back then- and it still works great. I've been playing w/ the idea of getting a diamond stone for it- it's pretty aggressive & is quicker for reprofiling than the Sharpmaker, which is tops for speed & convenience. You need to set blade angles for the Sharpmaker for it to work as intended. After that, the Sharpmaker is all you need unless you want/need to reprofile. YMMV.
Thanks for all the feedback.
General concensus seems to be to have both - I agree wholeheartedly with you on the inconvience issue ErikD - the stransky is a concern for me in terms of damaging the blade - I've taken to placing a piece cloth around the blade to protect it - just makes it a little slippery ( got a nasty little nick the last time I used it ) - I like the idea of the tape.
