You have to take the listing for the Spyderco stones with a grain of salt though. There is no "official" grit rating. The grit size is really the particle size (came from the grit through which the particles would fit through, so it was an upper bounds. These days, the techniques are much refined). The Spyderco stones all start with the same grit size, but they get processed differently. The stone get sintered. During the sintering process the particles fuse; they essentially melt, but not fully. They melt only at high points and in contact areas, leaving voids. If sintering it continued with sufficient flux and temperatures the particles continue to "deform" and the voids eventually fill (not completely but mostly) and the structure "smoothes out".
The gray stone are, AFAIK, open pore sintered, meaning the particles retain most of their structure, the whites are closed pore sintered, meaning most of the voids have been filled, and the UF stones are sintered like the white ones but additionally tumbled, to further smooth the surface of the stone. So it is pretty clear that a real "grit rating" isn't really possible anymore. All you can do is compare the scratches left by the ceramic stones, to those left by traditional stones. But that of course depends on how hard you press, and what condition the stones is in, so the comparison is somewhat subjective and all you going to get is a ballpark figure. Some people will argue for example that their UF stones are finer than a 6000 grit waterstone.
Personally, I would rate the Spyderco stones very similar as in DoW link.
Hope that helps and gives some perspective.
