Hi all!
I've been toying with this idea for a couple of months and I'm now getting pretty close to pulling the trigger and moving forward. Before I do, I would really like some feedback from my BF friends as to whether or not you think this type of testing would be valuable given the wealth of data that's currently available on BF and YouTube.
I'm considering doing steel testing using an Edge-On-Up PT50A. My idea for testing is as follows:
Take a knife, for example a Spyderco Paramilitary 2 in S110V. Measure thickness behind the edge with calipers. Sharpen to a course finish using a controlled angle sharpening system like the EdgePro or KME (say DMT course/325 grit). Test initial sharpness as measured with PT50. Then do a series of controlled cutting test such as 20 cuts through standard Amazon box cardboard (12 inch cuts, measured pieces of cardboard). Test sharpness again with PT50 and record difference from initial level. Then do a series of cuts through 5/8" manila rope -- start with 25 cuts, test sharpness again. Do 25 more cuts through rope, test again. Then compare the beginning sharpness, sharpness after cardboard, and final sharpness after all cuts and determine the % change.
Then re-sharpen the same knife at the same angle, but polish to a very high level -- say 0.1 micron as the final abrasive grit. Perform the same tests and compare the % decrease between the course and fine edge to determine which degrades the least in use.
What do you guys think of this protocol? Any suggestions? Would this type of testing be valuable to you?
I don't want to exactly duplicate the tests I've already seen which tend to involve extensive rope cutting, etc. until a knife stops being able to reliably slice a certain test media. I'm thinking that by doing the same number of cuts in the same types of materials, the tests will indicate what type of finish would be most durable under certain types of EDC use based on objective sharpness tests with a calibrated tester.
Thanks in advance for your feedback on this!
	 If you tell me what it is, I might be able to make a sensible suggestion (unless you feel "if this guy has to ask, I don't want his suggestions") which I would understand.
		 I believe that the more variables people test, the more likely a well founded decision can be made.
 I believe that the more variables people test, the more likely a well founded decision can be made.  So, for me, if what you test AND how you test it is somewhat different from what has previously been done you are helping.
 So, for me, if what you test AND how you test it is somewhat different from what has previously been done you are helping.  A big key is to NOT be repetitive.
