1095? If so, I'd also give some credit to the steel itself, which is known to take great 'shaving sharp' edges quite easily, with simple means
This ^
I am going to assume, perhaps wrongly, that you are asking for general sharpening and not for just shaving your face.
For general sharpening to produce tough edges to cut tough materials, cleanly, precisely and for long term durability then the finer stones are worth the money and time to use. I am thinking push cutting, woodworking chisels, plane blades, and I use knifes at work a lot this way to push cut trim hard rubber. I am not sawing my way through bushel baskets of rope.
Part of the reason you got such good results . . . I believe anyway . . . is that you got a thin foily wire edge and then made it pretty straight and relatively unragged with the leather. So FOR HAIR you got what you needed.
Great job by the way !
But for tough materials, wood / extra hard wood, hard rubber, tough plastic etc that foily edge would have folded over and got all dinged up.
ALSO
In the harder blade materials A-2, XHP-189 etc. the steel just laughs at a bare strop. It takes a few grits to really make a durable edge.
For instance when I got my Manix 2 CPM-S110V with it's toothy edge I tried it out and was kind of disgusted with how it felt, shaving wise, cutting wise, it just wasn't much. I stropped it on a rough strop with green on it and you could hear the blade laughing halfway down the block. IT JUST MADE ZERO DIFFERENCE. I have had that edge to mirror and toothy and back to mirror and for me an edge at least some where near 4000 to 8000 grit is all I am willing to use at this point.
Besides, look at all the pretty stones you could be spending money on and collecting.
You aren't going to let one little sharpening session ruin your stone collecting hobby are you ?
No of course not.
