- Feb 13, 2005
I have noticed that there are several guys here who make their own sheaths, I have sent out a few pm's to try to help guys out with how to get the back side stitches to come out better. I thought I would post it here. I have no where near the experience of some of the other sheath makers, but I think I have learned a lot and if this can help some of you out, thats great. If anyone has a better way to do it please post here. If there is interest in this subject, I would be glad to take and post some more pics.
Getting nice and even stitches on the back side of your sheath requires that the sheath have sides that are pretty close to perpendicular to start, so you need to be careful when sanding the sides so as to not get them out of whack. Next you will need some type of drill press, I tried this with a hand held drill and it is almost impossible to keep the holes straight.
Getting ready to drill, first make your groove for the stitches on the front of the sheath. Next mark your stitch holes. Make a template out of some type of flat wood so the sheath sits level and even, now set the drill press so that the bit comes to about 1/16 from the top of your piece of wood, you want the bit to go to the back of the sheath and make a little reverse dimple without popping through. Drill the marked holes on the front side with a drill press, or dremmel press (39.00 at Sears). Check the back side every third or fourth hole take make sure everything is ok.
When you finish drilling get your groover out and make a groove over the little dimples on back which will open the holes. As long as the sides of your sheath are both at 90% and you had a flat even piece of wood for it to sit on. Your back side stitches should be pretty nice and even.
If you have any attachments on the back of your sheath make a cut out in your piece of wood for the attachment to sit in, you must make sure your sheath is level or the holes will be screwed up.
Stitch the sheath and then go back over your stitches with an overstitcher, this kind of rounds the stitches off and makes them look nicer.
A couple pics.
Front side
Back side
Finished
A couple pics.
Front side
Back side
Finished
