Sheath for 307
Anyone have an idea what buck sheath would fit a307 wrangler. I hate it in my pocket. thanks...Tom
The 500 sheath would probably be the closest fit. A 112 sheath would work too, but the knife would flop around a bit inside.
When I haven't been able to find an exact match sheath for one of my edc's. I've used dense foam inserts to get a custom fit and keep the knife from flopping around.
One of the nylon 424 sheaths should be a decent fit. The two knives are somewhat similar in length and girth. Should you prefer a leather sheath, the 501 sheath should fit the bill. I will go home at lunch and see how the fit is. I have two or three extra 501 sheaths so perhaps one of them will work for you.
I have a leather sheath made for a 4 1/8 inch closed Trapper, that will also hold a 4 1/4 inch stockman.
Worst case, (no pun intended), Case makes a sheath for their "54" pattern Trappers that fit's a 307 to.
But is says "Trapper" on the front.....
Larry,,
I sent you an email about a new 118 Sheath while you are checking.
Thanks!
well, I checked the sheaths. The leather 501 sheath is too small. The 424 nylon sheath will just barely work although the velcro at the top does not fully adhere due to the length of the 307. A 426 nylon sheath will hold a 110 so that may be better, especially if you place a small piece of foam in the bottom of the sheath to take up any extra space.
It's not a Buck or even a belt sheath. I am still good using Ron Ryders -cuttersandcollectors.com- Buckaroo sheaths for EDC 300's. A large one should fit a 307. The belt strap keeps the sheath from falling to bottom of your pocket. Stopping embarassing "pocket bulge". Didn't Mae West have some famous line about that. The sheath hangs along the seam line of jeans or to the side in pants. I can pull my 301 or 303 out with two fingers and I don't worry about catching sheath on car seats, chairs etc.
I have no interest in company just a product I found to be useful.
