Sheath for a buck 55 ?
Does anyone know where I can get a sheath, leather or nylon, for a Buck 55 ?
Ask Buck. May be, that Joe H. can help you.
Best,
Haebbie
P.S.: It is possible too that I have one, but it is a long way
from Germany to the States. But at first I have to
have a look. Pleas tell me if it is necessary.
The 55 is a tad smaller than the 501. Here is what a 55 looks like in a 501 sheath. You can see the mark in the leather just above the 55 where the 501 comes to. The 55 sits a little lower but not bad. The 501 is alongside. 501 sheaths are available on the factory website. HTH /Roger
cm,
This is how I carry mine. I buy pre-made slips from a maker of your choice. Then I braid a lanyard using 45 year old Boy Scout skills.
This all hangs from my belt inside my front pocket and over to the side where the outline is not visible...also use some 35lb bass fishing line braided up for a less obvious belt lanyard. Use this on my 300s and my single SAK (Sunday, the screwdrivers for sound system emergencies).
300Bucks
Found a couple of 501 sheaths on ebay. Will pop in a bit of foam inside at the bottom to lift the knife up a bit to make it easy to pull out.
Thanks to all for prompt replies.
