- Mar 19, 2007
Pattern traced for a similar knife.
Initial pattern cut for knife - with belt loop left long (to be adjusted to the knife once fitted.
Sheath is dampened and initial fitting is done. I didn't like how large the sheath was - so I trimmed about 1/4 inch off the outside of the sheath total.
Sheath trimmed and inside grooves cut from the blade down to make a more form fitting sheath. Belt loop is cut at this point.
Secondary fitting to show the lines and check for general look. Much cutting and sanding happened here.
Custom welt pattern made and welt cut.
Welt cut and traced on the knife to ensure fitting and mark glue lines.
Makers mark put on the back.
Belt loop and the majority of the opening burnished.
Welt skived and inside of sheath and welt glued.
Welt glued in - skive marks obvious here.
Welt cut even with the sheath and primarily sanded.
Stitch groves cut and stitch marker used to mark stitched. Some manual adjstment was needed toward the tip.
Holes punched and overstitcher used to set where stitching will go.
cont...
