Sheath making part 2
Now we will get another piece and cut the welt out. Trace the knife again making sure you line it up with your bottom and back pieces. I like the main welt piece (the one that contacts the edge) to be one solid piece of leather. There are other ways to do this and none are wrong.
Now cut out the welt. This will leave a knife blade shaped piece of leather which I use to make two additional welt pieces to help build up the thickness of the sheath, due to the thickness of the blade. Just lay your first welt on top of the knife shaped leather and trace and cut. Next the additional welt will need to be skived.
Check for fit.
We are now onto the front piece of leather which I cut a little oversize to allow for wet forming. I put this in warm water (about 110-115%) for about 5 minutes. Take it out and pat it dry, and then let it sit for about 30-45 minutes. Then put it on top of your knife and other pieces you have stacked and wet form it using your fingers. If you have long nails cut them. Only use the pads of your fingers and push and smooth it to shape. This should take about five minutes. Take that wet piece of leather and set it somewhere to dry. I make sure it is all the way dry before I mess with it again. A dehydrator will work on low setting to dry it in a few hours also or just let it set out overnight. It is dry when the color is back to normal and it does not feel cool to the touch.
Now clean dry and oil your knife.
End of part two.
Cool, I need to go back print the first... and try to keep up.
You make it look so easy I'm starting to think I might could do it.
Big might though.
thanks for sharing:thumbup:
