Sheath Mod Bad for Blade?
Greetings Everyone. Glad to be here.
Just recently bought an ESEE Junglas and couldn't be happier. I'm now looking to mod the kydex/MOLLE sheath it comes with and want to add a small pouch to it for a Ferro Rod and some DMT Sharpeners.
Trying to find a pouch that I can just use the empty holes and screw it to the sheath but haven't had any luck as the ESEE Accessory Pouch is too narrow. Anyone know of anything? Trying to find one in Ranger Green.
Would zip tying or tying 550 paracord around the sheath cause the blade to dull as I pull it out and put it back in the kydex because it's too tight around the blade?
I know of the MOLLE panel, but I'd want the pouch to be firmly attached to the sheath and not sliding around.
Thank you and God Bless.
maybe use a split ring fed through the hole of a ferro rod which is connected to a carabiner that is attached to another split ring to the kydex sheath, it'll rattle but it will be made well
search for a pouch with eyelets on the edges and tie it up with paracord, it won't affect the blade at all. The kydex sheath on the Junglas is one of the best factory-made kydex sheaths I've ever seen.
