Sheath/mollie lock problems
Im not sure if my the holes on my sheath are just out of place or maybe Im just not doing something right. I have tried this every possible way, but the holes will not line up.
Any suggestions?
Hey Bro, welcome to the forum!
Your doing it right. The Molle locks will only allow you to use one screw when in the horizontal position.
Don't worry, both the sheath and Molle lock are plenty flexable and strong to handle only the top screw.
That is strange the mollie on the right lined up perfectly for both screws.....
oh well it is still an amazing knife
I disregarded the molle clip and used a tec-lok. I use one on all my kydex.
They're the best Jerry, the best! :thumbup:
I've heard the tec-locs are overly bulky.
What's the general consensus on that? Do the pros outweigh the cons.
I'm on the fence about grabbing a tec-loc. But I guess it's only like $6 so I should just get one and find out...
tec's are nice on a belt really. I've personally moved back to all the RAT belt clips now however, except for my RC4, which is molle locked to my daybag.
I like MOLLE Locks because they work on MOLLE gear OR on the belt!
There is a slight difference in spacing between top holes and bottom holes. But it does work. Try putting the screws and posts on very loose (use rubber washers in the middle also). As soon as the screw threads get started then tighten them up. I've done it many times and it will work. It slightly bows the MOLLE clip back but not enough to hurt the performance. Mike
