- Sep 27, 2017
The clip on my Secure-Ex sheath broke off and I was wondering if anyone knew of a good replacement sheath for the Kobun. It's an earlier model that does not have the separate metal clip on the sheath. Thanks.
You designed the g-clip? That’s awesome man! Yes you are right about eBay. I have a particular seller on there that makes great sheaths for a variety of blades that come with tek loks or g clips. I love it on mine. Carry it at 10 o’clock handle down, can’t see it under my shirt and I forget it’s there because the thin profile.Be careful what you get off eBay. There is a big variance in the quality of "custom sheaths" across the board, and like I said, a good sheath will cost at least as much as a new Kobun.
Nice set up. If you want, you can cut/grind a little off the bottom plate from the G_Clip to make it a smaller profile. WhenI know a sheath will be used primarily for horizontal or angled carry, I will take a little off the bottom part of the plate.
That’s nice work there. Thats a great idea, I will do that, thanks. It does jab me a little bit when I sit down.
Interesting wrap.You designed the g-clip? That’s awesome man! Yes you are right about eBay. I have a particular seller on there that makes great sheaths for a variety of blades that come with tek loks or g clips. I love it on mine. Carry it at 10 o’clock handle down, can’t see it under my shirt and I forget it’s there because the thin profile.
[/IMG]![]()
Interesting wrap.
Looks good, from what I can see.
The Kobun is an excellent candidate for wrapping due to the slim profile of the handle.
Would you mind posting, how you wrapped the Kobun handle, pls?
This is a good illustration. Just make X's across each side of the handle while twisting the cord. I gutted paracord and only twisted once across the handle each time instead of twice like this video. Its very easy and basic, but makes the handle feel way better, more hand filling.
Forgot to quote your post. ^^^
Awesome. Thx
Do you make a knot, when you reach the end or just shove the ends of the cord under the last 'X' and epoxy them or .... ?
Have Kobun, off to gut some paracord ...![]()
I just tied a knot, cut the excess from each end, put a lighter to it and pressed it to the wrapped handle when it was hot. I guess there are many ways to do it but the good thing is the ends cross so you can easily tie a knot at the end.
