There are 5 nails that I can see on my sheath. 4 of them are used in affixing the loops which sheath the Karda and the Chakma. The last one tacks down the leather flap on the back side of the sheath along the stitched seam. My question is, can I remove these nails and replace them with liberal drops of super glue, without compromising the integrity of the leather. Will it cause things to unravel or come undone if I remove the nails?
Also, I immersed the sheath in warm water as I am anticipating using my Khukuri in jungle conditions. The leather flaps just inside the mouth of the scabbard came up... Should I simply super glue them back down, leave them be, or is there a better glue I should use?
The last part of my question has to do with the wood of the sheath. Should I treat the interior wood of the sheath? If so, what do you suggest? Should I leave it alone and preserve the water-wicking properties of the wood? Gah! Who knew that owning a Khukuri could be so complicated? *L*
When the chips are down, the buffalo is empty.
