- Jan 27, 2008
I'm currently making a sheath for a fairly large chopper I just finished. I thought I'd put up a WIP sequence showing how I do it in the hopes that it will generate hints, tips and nuggets of wisdom from some of the more accomplished leather workers in this community and become a learning tool for all involved.
So, here's yesterday's progress:
I have already done one of my more time-consuming steps.... the layout work with pencil and paper. I spend hours doing this. Its the process where I can envision all the little design nuances and technical steps of assembly. I try to get it right here so I don't have to screw around during the build.
These are all the pieces and parts needed for the basic assembly. I have here:
- a piece of Wickett & Craig 6/7 oz veg tanned leather
- my hand drawn template
- a chunk of Red Maple "onion" burl
- a couple of gouges
- a good straight edge and an Exact-o-Knife with a few extra blades
- more hand tools will come into play later in the process
Using the straight edge and a very steady hand, I cut out the various parts from the basic cardboard template then proceeded to trace the outlines onto the leather
I'll cut out the leather pieces later. Right now I want to get the inlay started. The outline is first traced onto the block. Then I use a brand new, sharp razor blade in my utility knife to cut a "stop cut" along the outline. Finally, it is cut out on the scroll saw.
The lines are cleaned up on the belt grinder:
The piece of approx. 1/2" thick so I have enough material to work with to get a nicely raised-surface inlay.
Now the work starts! Using my dremmel, I begin to "route" out the edges.
Continuing with the dremmel. I find that I can hold it down against the table and move the work piece under the spinning bit.... much like a real table router. I'm just about done with the rough shaping of this piece. I'll fine tune the edge with files and a sanding block to get a perfectly flat, smooth stitching surface.
I want the stitching lip to be THIN. I don't want a bulky hunk of wood restricting the movement of the blade in the sheath.
I removed most of whats needed with my 4"x36" belt grinder, then I finish the job with sand paper and smooth granite block.
The finished inlay ready for Tung oil and polishing:
Did I say I wanted this to be thin? There's still enough meat there to make an underside stitching groove without compromising the strength or integrity of the inlay piece.
It fits!! Yeahhhh!!
While the first coat of Tung oil dries on the inlay, I need to make the welt thicker to accommodate the blade. I'm gluing a piece of split to both sides of the welt. That will do just fine.
On to the belt harness(that will later be changed a bit). I punched and cut out the loop slits:
Now I need to make three brass D-rings. The 1/8" pin is marked and the ends bent:
A production line!
The piece is hammer-bent over a steel rod:
The ends are fine tuned on the belt sander so they meet up just "so".
They get cleaned up a bit.
One down:
Done!!
Now its on to the copper tip piece thingy(the technical term). I have forged out a plate of solid copper that I am now cleaning up on the belt grinder to make it flat and smooth.
Using the original cardboard template, I traced, then cut out the copper piece with a hack saw then cleaned it up on the belt grinder. Now I'm filing it to the near-final shape:
Finally for the day, I cut off two coins from a wrought iron chain link. Here, I have finished rough-shaping the first of two decorative "stars" for the sheath face. These will get holes drilled, beveled edges and a good polishing before being etched in ferric chloride and then final polished.
That's all for today. Stay tuned......
-Peter
It fits!! Yeahhhh!!
A production line!
One down:
Done!!
-Peter
