- Jun 26, 2015
I dont understand the point of loose bearings. Taking one apart to clean has to be a pain and if you accidentally lose a bearing or 2 then what? Just doesn't seem to be very consumer friendly.
Yeah those knives are just for Rolex Submariner owners who don't even go near water except the occasionally vacation with the wife by the shore. Yes they probably only marry the ones that constantly complain about the beach.I can’t imagine most people that own a Shirogorov, especially the higher end ones, use them in an environment where repeated cleanings are necessary. I bet a can of compressed air sprayed in the pivot and the occasional drop or two of KPL would be enough to maintain the knife without disassembly for a long time.
I agree that it’s not something to be attempted by the average person without a solid understanding of that they are up against, but as long as you are careful and prepare beforehand it probably isn’t too bad.
Never handled a Holt but I'm of the opinion that they're overrated and overshadowed by makers like Shirogorov. If the Specter sold at table price I can see that, otherwise it's a hard pass.I am not an engineer, but it seems to me that "caged" bearings introduce more surface contact (i.e. "friction") on the balls vs. individual balls that ride loose in the pivot groove.
Anecdotally, my Shirogorov F3R with loose bearings is much smoother than the Holt Specter I had with caged bearings. I let the Holt go, kept the Shiro, and have not looked back.
Phil
seems like sealed bearings (like skateboard wheels) would be the way to go for pocket knives.
Skateboard bearings are designed for radial loads. Knife bearings are designed for axial loads.
Does anybody make captive/caged multi-row bearings? That'd be a pretty substantial barrier to using them...
My only qualm is I've opened up my shiro and they were all dusty on the inside. Dust from the factory, including CF dust. The action is much improved once I removed the Militec grease they apply and add KPL. I wouldn't take them apart had they been cleaned well and a good lubricant was applied.Shiro actually does and did some testing.
https://www.bladeforums.com/threads/sbw_flipper-95-bearings-pivot-point-test.1263295/
At the end of the day. I still feel the constant need to take things apart is not a must for knives.
Nothing I have found that warm soapy water and a bit of oil cant sort out and I used my loose bearing folders since I was in the oil and gas industry till my office job today. Never taken apart.
It's really not that big a deal considering the other issues. There's no perfect package out thereI'm not hating as I want a shiro at some point. I just dont think loose bearings is a positive from a consumers point of view.
