Nuker
- Jun 22, 2024
I’m hoping to learn the relative age & match them up with the correct sheath. Any help or error correction greatly appreciated.
All MS are pre-fall 2000 (Lean MS came after MS) per this post by a former Busse dealer.
So the bolts came first… Eagle sheaths with cowdex insert. Do bolt handles go with kydex or Eagle?
Anyone know production date range for smooth vs. slotted vs. tube rivet?
i.e.
Smooth: start - end
Slotted: start - end
Rivet: start - end fall 2000
Both bolt handles have small talon hole, A2, smooth earlier than slotted.
Cowdex insert: (sort of fuzzy inside)
Eagle sheaths: Which one goes with smooth or slotted bolt, or with rivet?
Some of the variances noted below may be general differences between each sheath assembler, but there may be a timeline clue.
I’ll go by this one as the “pull the dot” (PTD), snap type.
PTD variance #1: vertical stitch on reverse
PTD Variance #2: wider spaced rivets at the bottom & insert sits shallow.
I’ll go by this one as the “One Way” (OW), snap type.
OW variance #1: no vertical stitch on reverse (like PTD sheath)
OW variance #2: rivets close together & insert sits deeper:
Now for the rivet handle knives… could be INFI, but most likely A2.
One knife has: rough coat, small talon hole (0.145” dia), 0.257” thick.
One knife has: smooth coat, large talon hole (0.211” dia), 0.281” thick.
One sheath has: dimple for tube rivet, smooth texture, folded over belt loop.
One sheath has: no dimple, rough texture, riveted belt loop, drain hole in back side (could have been added by anyone).
Thank you for any help!
i.e.
Smooth: start - end
