Sando
Knife Maker
- Jul 4, 2002
You know how the first glue war ended in a tie. Everything seemed to fail.
Well I did a second test on that bar and used a coarser finish on the steel (80 grit). Cleaned the bar with Simple Green, rinse, then Brake Cleaner (instead of lectra-clean).
Guess what west systems, devcon, JB Weld all came off with a push. JB Weld just fell off.
Was it stainless or what? So I redid some samples
I abraded the ATS-34 bar and glued on DEVCON, JBWELD and Gorilla Glue. No washing. Didn't touch the bar, right from the grinder to the glue
Then I made a sample with mild steel, but used Simple Green and brake cleaner. Then E-120hp and JB Weld.
Guess what? The JB Weld popped off the mild steel after the dishwasher test, but the sample on the unwashed stainless is just fine.
So........
Either Simple Green or Brake cleaner is a very BAD idea. I use alot of xylene based brake cleaner. I don't think that's it. I think it's the Simple Green. Maybe the fragrance they use ????? beats me, but I'm staying away from the stuff. (Yes I did rinse, but not very long .... evidently)
It wasn't the epoxies that failed. It was the cleaning.
The entire first round of Glue Wars meant nothing for the glues.
Steve
So........
Steve
