i've worn out shooting gloves. oakleys, wileyx, hatch, damascus, vickers, and mechanixs. a few that i didn't know the name of.
the oakleys arn't bad, used to be better, not worth the money unless you get a discount.(as in issue)
the wileys SUCK. MATERIALS AND FIT.
the best i've found so far are the damascus hard knuckle, go somewhere to try them on if you can.
the hatch hard knuckle are the second best i've found, again go someplace to try them on if you can.
a lot of the guys i've worked with use the mechanix, nice gloves and cheap enough that you can buy 5 or 6 to take on deployment.
the older vickers are nice but the new ones aren't made as well
shooting gloves will last longer if they fit right, meaning not second skin tight. if they are a bit big(half size) you can wet them and get them to fit right. if they are tight the seems will pull apart quick.
A few people shoot better with gloves because they are more conscious of what they are doing because of the gloves, they actually see the sights. good gloves help a lot, especially when its cold. numb fingers don't work as well and you don't feel all the little nicks and abrasions that after a day or so can make the class a lot harder and maybe even unsafe.
get a good pair of gloves and practise in them.
have fun in class.
