Ankerson
Knife and Computer Geek
- Nov 2, 2002
Been wanting to do this for awhile, a direct straight edge retention comparison between these two steels. They are very close in performance, closer than some would believe. Both knives are CF Sprint run Military's sharpened to 400 grit Congress Moldmaster finish at 15 degrees per side. This leaves IMO the optimal edge finish for maximum edge retention and cutting efficiency.
The Test:
Slicing 5/8" Manila rope checking every 20 cuts for down force and cutting was continued until 20 LBS was reached. Starting force was 11 LBS for both knives and after 20 cuts both knives were at 14 LBS.
The Steels:
M390
C - 1.9%
Mo - 1.0%
Si - .70%
W - .60%
Cr - 20%
Mn - .30%
V - 4.0%
CPM S90V
C - 2.30%
Mo - 1.0%
Cr - 14.0%
V - 9.0%
M390
Cut aggressive with the edge finish and took some edge damage as expected as all steels have, it was still sharp enough to slice printer paper after testing.
CPM S90V
Very Aggressive with the edge finish and as with M390 it took some edge damage, but slightly less. Sharp enough to slice printer paper after testing.
Knives together.
Results:
Both knives performed extremely well as expected with S90V over M390 in the end by 21% or 460 to 380 cuts.
Very close as I expected it to be, under normal use most wouldn't be able to tell them apart depending on actual use unless they were pushed to the limit of edge retention. In that case the added Vanadium content of S90V at 9% over M390 at 4% would take over.
The Test:
The Steels:
M390
C - 1.9%
Mo - 1.0%
Si - .70%
W - .60%
Cr - 20%
Mn - .30%
V - 4.0%
CPM S90V
C - 2.30%
Mo - 1.0%
Cr - 14.0%
V - 9.0%
M390
CPM S90V
Knives together.
Results:
