- Jan 1, 2018
Need some opinions and experience on what to consider when laying out a shop. I will be running 220v and air throughout. No plans for a washroom as there is no water.
I have an old cinder block barn with 14 ft ceilings, with a 30ft by 42ft concrete floor and a 15ft by 42ft lean-too. The inside of the barn has 14ft ceilings. It's time to start sinking some money into the shop as the rood needs replacing, a corner of the floor needs mud jacking and its an eyesore.
I'm looking at having a concrete pad placed under the lean-too, the barn floor jacked and the roof replaced this year. Next year I'll clad it and fix up the inside. I'm just trying to work out some floor plans as I hoping to not handcuff myself in the future. I'm considering getting a sea container to store the toys but if can id rather do without. The shop is not heated so I want to build a dedicated knife room that I can heat instead of heating the whole barn.
I'm thinking that the lean-too portion will be a dedicated wood working shop. The main barn will be mechanics, welding and knives. Here's a list of things that have to go in the barn, things that will eventually go in and future hopefuls.
Current stuff
Tig Welder/plasma cutter, parts washer, sandblaster, grinder, belt/disk sander/ 80 gallon AC, table saw, miter saw, metal band saw, planer, drill presses (2), on and off road toys, tool boxes, shelving, various vises HT oven and dewar.
Future stuff
welding / fixture table (3x6 ish), dust collector, car hoist, wood band saw, 2nd grinder, forge, forge press. I don't forge but may want to try at some point.
Hopefuls (if the wife doesn't divorce me after this project)
Mill, lathe,
The idea is to have a somewhat small knife room that will house the grinders assembly table and storage. I don't like the idea of assembling in the grinder room but frozen epoxy in the winter sucks. I might partition off the grinders to keep the dust down from the assembly area. With a 14 ceiling, I want to have a 6.5 to 7 foot grinding room so I will have a short storage area on top. I guess the knife room would house the grinders, oven, dewar, vise, drill press belt storage, work bench and cupboards.
The biggest issue is the room needed for a car hoist (12x24) plus the room my car project is taking up. I also have a few motorcycles and lawn tractors. If I do get a sea can, they'll be stored in that. I may ditch the hoist idea in favor of more space but my car is taking up the room anyways.
Have a look at the floor plans below and let me know if anything jumps out at you.
i'm not a fan of the first one because it'll be a pain to get the mower out past the car and a 9 by 14 knife room seems a little too big.
the second looks good. lots of open space near the main door for the mower. 9x14 knife room again seems a little larger than it needs to be
I like the third option the best. It really opens things up and gives a ton of storage over the knife room and mezzanine. Also lots of open space for toys. A 5 x 10 knife room might be a bit small though to hose grinders, oven, dewar, drill press, storage and a work bench. If i ever do start forging, it'll be in the main shop.
Current stuff
Future stuff
Mill, lathe,
